Jimbo714
Posts
28 -
Joined
Last visited
Days Won
4
Content Type
Store
Calendar
Forums
Gallery
Downloads
Posts posted by Jimbo714
It’s b18c4 bud,
- 1
Hi...
so the civic has been good for 7000 miles since top end rebuild, in till the other day where I driven half a mile down the road developed a misfire, after investigation changed plugs dizzy cap and rota, when I took the cap of and found the rota arm screw loose an stuck to the magnet in the distributor, so all put back together and done a oil change,
now the car is intermittent on starting and once it is starting it’s fine but doesn’t seem to be using vtech and a slight rasp coming from the exhaust at high revs.
any advice gratefulthanks
Hi all, can someone tell me if the integra exhaust from cat back is the same as my mb6
thanks
Standard cap, when hot the hoses feel fairly stiff,
should the top and bottom hose feel pressured when warm ???
Hey, put the radiator and hoses all on. An having problems!
cant seem to get hot air from heaters, temperature is on half, any help be appreciated
Thanks for all reply’s, just got it back together again, all fine !
Running good and all dry,
- 2
Thank you, just waiting to get my head back and can start building
- 1
On the hunt for complete timing belt covers front and rear,
Any suggestions on where to buy parts, rings gasket shells etc
To be fair there both rust free, 1.5 is 80,000 miles and 1.8 50,000, both never been welded,
do I have to change the front hubs to allow for the 1.8 shafts, and the Rear roll bar and axle brace bolt straight on the 1.5 ?, also is the clocks straight forwaRd swap
thanks
Just had a quick look over and the radiator is bone dry and expansion bottle has a silver thick residual, so most definitely head gasket I would say, but possibly a bit more internal damage???
Elderly lady 1 owner from new, m.o.t in till next year not greatly serviced 60,000 on the clock, she recently had a flat battery so got it jumped and was told to pop back out to car to turn it off in half hour in which she fell asleep for 6 hours with the coolant fan not working, so had a quick look as it’s swinging over but won’t fire ???? But for £60 I can grumble
- 1
Hi. Can any one help with engine code and hp etc Of a Aerodeck 1.6 1999 ?
Thanks
Just got hold of a accord 2.0 vetch 1998- 99, what amount of work am I looking at to swap engine over ?? Tia
Intermittent starting issues
in SOS! Help!!
Posted
Just update, new coil fitted and seems to fixed all problems, thanks for all reply’s
