JK1245 Posted August 18, 2016 Share Posted August 18, 2016 Yes mate vtec was more pronounced on mine when I fitted it, even now when I swapped my whales p***s for the Dc2 box and pipe it sounds louder than my mates mb. Could also be an idea to bend the throttle cable bracket down a bit if you plan on keeping the c4 throttle body because the intake mani sits a lot higher than the old one and I had the problem whereby the throttle cable would rub on the bonnet when letting off after WOT. Quote Link to comment Share on other sites More sharing options...
dogg1210 Posted August 18, 2016 Author Share Posted August 18, 2016 Do I just need to hit it down lol 1 hour ago, JK1245 said: Yes mate vtec was more pronounced on mine when I fitted it, even now when I swapped my whales p***s for the Dc2 box and pipe it sounds louder than my mates mb. Could also be an idea to bend the throttle cable bracket down a bit if you plan on keeping the c4 throttle body because the intake mani sits a lot higher than the old one and I had the problem whereby the throttle cable would rub on the bonnet when letting off after WOT. Do I just need to hit it down lol Quote Link to comment Share on other sites More sharing options...
Finch Posted August 18, 2016 Share Posted August 18, 2016 5 minutes ago, dogg1210 said: Do I just need to hit it down lol if its not a cast bracket you can probably bend it by hand, saves potentially smashing anything with 'omma Quote Link to comment Share on other sites More sharing options...
dogg1210 Posted August 18, 2016 Author Share Posted August 18, 2016 Lol cheers bud Quote Link to comment Share on other sites More sharing options...
dogg1210 Posted August 18, 2016 Author Share Posted August 18, 2016 What way will it need to be bent Quote Link to comment Share on other sites More sharing options...
Chandler Posted August 18, 2016 Share Posted August 18, 2016 use a hammer, hit it as much as you can 2 Quote Link to comment Share on other sites More sharing options...
dogg1210 Posted August 24, 2016 Author Share Posted August 24, 2016 Right it's on now but am still at work the mechanic that fitted it says there's a vibration thro accelerator pedal I take it this will be the throttle cable hitting the bonnet, how do I mod the original bracket to stop this, cheers Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 24, 2016 Share Posted August 24, 2016 Bend it hit it cut it... do whatever stops it hitting the bonnet. Quote Link to comment Share on other sites More sharing options...
dogg1210 Posted August 24, 2016 Author Share Posted August 24, 2016 Lol ordered a bracket from tegiwa Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 24, 2016 Share Posted August 24, 2016 Or that Quote Link to comment Share on other sites More sharing options...
