Sign in to follow this
Rainy
MB6 Dashboard Dimmer
Hello Iam new here and Iam looking for dashboard dimmer from MB6 to my MB3 :)
Share this post
Link to post
Hi Robert. I have these in stock, not sure what the postage to Slovakia will be though? I will try and find out for you.
Share this post
Link to post
Hello Dave :) shouldn´t be much, do you know if it will be compatible with my MB3 though? :o
Share this post
Link to post
If your mb3 had the switch fitted as standard and your just looking forward replacement then yes mate straight fit. If you're retro fitting it, you'll probably need the extra wiring harness that would have been fitted from the factory.  If yours has the dimmer but not the h/light washers, I think the plug is different for the switch in the photo. You can get the harness from any mb that has the headlight washers, or try our trader 10000RPM as he might be able to source the harness for you. Not sure if there's a difference between right hand/left hand drive models though.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
