  • 0
B18 engine problem
mokus
Question
Hi!
A friend of mine bought an MC2 1.8 vti +LPG.
Today I drove the car and it has a strange engine problem.
Pulls almost fine, nothing too bad problem, so its stock"ish" power I think.
Only problem is, when I drive it easy (throttle lightly, normal city drive), throttle disappears for 2-3 seconds, I feel it on the pedal, nothing happens, then it kicks and pulls again.
Its around 2600-2800rpm, i drove it in 3th gear, and I could repeat the problem again, so its that range, where its bad,
Any ideas? :\
7 answers to this question
  • 0
Thank you.
A little update. Leads changed to new ones, but it was still bad, especially when warm.
My friend changed the rotor, he said it looks better now. Tomorrow I gonna go there and check.
Next step is coil change, maybe ignition control module change. Then if its still sucks, next will we o2 sensor.
Thats the plan
  • 0
Today it didnt started with warm engine. I drove there, it was there 1 hour already. Took apart the dizzy, nothing looks wrong. After two tries it started.
BUT the dizzy... its a f*ckin aftermarket sh*t*
Inner end of the shaft is like loosen, contol module not NEC... its a s**tty dizzy. Even the seal of the cap was a bit big for this dizzy...
but it has a TD-86U sticker on it.
I think all the problem is from this s**t :\
I told him to buy a complete oem one, Or rebuild my old spare one.
Answer this question...
