  • 0
Lower front engine mounts B18C4
Dexter
I need to change mine but despite serious googling and cross-referencing, can't seem to find a lower right mount. Lower left ones are plenty available and seem to be compatible between pretty much any d- and b-engine honda, but for some reason it's not the case with the lower right ones. Does anyone know where to find one, or if other mounts are compatible? Oem code for the part in question 50841-ST3-E51.
1 answer to this question
  • 0
Problem solved... i guess sometimes it's worth googling with the name of the part instead of the oem part number :rolleyes:. Turns out both the lower side mounts are very intercompatible, i ended up buying a pair intended for a b20 Stepwagon.
Answer this question...
