  • 0
Sign in to follow this
ChosenOne
Front wheel bearings
Hello again; I recently changed all the brake pads and brake discs plus both rear wheel bearings but now I noticed that either one or both the front wheels bearing scream like crazy, especially between 90 - 100 km/h !
My parts guy can't tell me precisely what I need because he's not sure if the wheel bearing comes with the hub or no. Could you guys help me out here please ? Does the bearing come with the hub ? If not, does anybody know the size of the wheel bearing ? Thanks!
Share this post
Link to post
7 answers to this question
  • 1
The bearing comes appart of the hub. You only have to change it. Its not dificult but you will need a hydraulic press to put it on, so maybe better to do by a professional.
I cant tell you the size of the bearing but with the car model your car parts guy should not have problems to find it.
Good luck!
Share this post
Link to post
  • 0
So I got all the bearings replaced (all four of them) but the car is still noisy at 100+ km/h ! What else could cause the noise ? My EK Civic is super silent at such speed but the Aerodeck is pretty loud
Share this post
Link to post
  • 0
try swapping the wheels over and see if that changes anything?
could be the tyres..?
Share this post
Link to post
  • 0
Winter tyres could also be causing your issues.
Like already mentioned by Daniel.....try swapping the front wheels with the back ones.
If you still have no joy it's time to start looking at your drive shafts.
Good luck :)
Share this post
Link to post
  • 0
Thank you so much guys (: I'll look into it! I already ordered new tires because I found out that the ones I bought are actually the cheapest winter tires on the market here (23 euros a piece) and I'm really not sure why the hell I bought them. I hope that will be issue :D
Share this post
Link to post
  • 0
Deffo change the tyres front to back mate. Does the noise seem to come from the front, and if so any particular side? There can be a few things cause this, such as a caliper binding. I have a noise front the drivers side front on the deck just now due to the caliper binding (quite badly in this case!) so get a droning noise from it. Are you seeing more brake dust on one wheel compared to the other?
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
Answer this question...
  Only 75 emoticons maximum are allowed.
