Buzzing noise drain my battery
adeel
have a mb6 Everytime i switch car off there is a buzzing noise coming from under the brake servo. And this drains my battery. Its like a noise the fuel pump makes when u put ignition on. Can anybody advise what this could be
The abs pump is under the servo. Maybe that? There is a fuse above the right side engine mount. Maybe see if you pull that out does your noise go away? You may have to reset the abs light after this though. There is a guide on here somewhere.
Yeah, exactly as Jake says. Most likely the abs pump as the servo itself can't really make the noise described. Are there any relays on the inner wing near there as it could also be one of those making the noise?
