  • 0
Rear caliper bearings
dr_broon
Question
So I'm getting my calipers refurbished by a local chap who normally does Jag brakes. He's hit a bit of a brick wall with the rears, as it seems that whoever reconditioned them last used some sort of plastic sleeve instead of the needle bearings for the handbrake mechanism, which has now disintegrated (probably due to the heat of a siezed handbrake.....).
Now, honda don't seem to sell (or even list a part number) for the needle roller bearings, and trawling through the Internet seems to confirm this.
What I'm trying to find out is what is used when calipers are remanufactured - any chance that anyone knows?
I've seen on a forum in America that someone found a brass sleeve in their remanufactured ones for a teg.
Obviously why they don't tend to last as long as the original ones.
  • 0
Yeah, problem is that I don't have the calipers at the moment, and the bearings had been removed in the past.
I've gave it a shot in the spirit of discovery, so will see if they're right... Fingers crossed.
  • 0
But if you got recon calipers surely they'd have the bearings replaced in them? And if so, then where are the recon companies getting them? Have to come from somewhere so they have to be available. seeya.gif1
  • 0
Well, it seems that the bearings might not always be replaced with bearings when refurbished... Think that a plastic sleeve might be a common thing.
Could be why I've had umpteen rear calipers over the years.
I'm hopeful about these bearings though. [smash.gif]
  • 0
There easy enough to do your self if you have a mechanical understanding of some degree lol I finished mine last night and it only cost £40 to rebuild both rears and roughly about same again to do the front ones next. But if you’re not confident then I would suggest to have someone who is capable of doing the job as it’s safety over cost after all.
  • 0
12 hours ago, dr_broon said:
Arrived yesterday, dropped them off last night, and after some mild grinding of the caliper to clean up the chamber, it fitted like a glove applause.gif1
Massive props to @shebabby for pointing me in the right direction on ebay.
For anyone else in Internet land who needs needle roller bearings with a hole for honda brake caliper handbrake mechanisms, you need
7E-HKS BA1012 Needle Roller Bearing with Hole 15.875x20.638x19.05mm
I got mine from the seller named cardiff-deals
https://www.ebay.co.uk/itm/202541737100
Happy days again mate lol
  • Thanks 1
Answer this question...
