integraz Posted June 27, 2009 Share Posted June 27, 2009 guys iv got a mb6 and as you know how crap the gear ratio are on the s9b,so iam thinking what shall i do get a s80 but they are expensive???is there any way to sort it out??if you know any1 let me know.thanks Link to comment Share on other sites More sharing options...
civicturbo79 Posted June 27, 2009 Share Posted June 27, 2009 You could get someone to rebuild the gearbox with the ratios you want but that would cost loads more than a s80 box i would just save the money and get one . unless you do want i did get 350 bhp + and the ratios are not a problem. Link to comment Share on other sites More sharing options...
Dave Posted June 27, 2009 Share Posted June 27, 2009 yeah s80 is deff the way to go. It's one of the best and worthwhile mods for an mb6 there is. Link to comment Share on other sites More sharing options...
BLAMES-VTi Posted June 29, 2009 Share Posted June 29, 2009 S80 gearbox is one of the best thing you can do! Top priority over exhausts,induction. Car feels completely different. get a s80 gearbox for about 450-650 depending on mileage and condition. then id recommend fitting a new clutch and lightweight flywheel. so you can be looking around the £1k mark. but its all worth it! Link to comment Share on other sites More sharing options...
integraz Posted July 5, 2009 Author Share Posted July 5, 2009 yeah but thats alot off money?was thinking if some1 knows who can sort the gear ratios out?? Link to comment Share on other sites More sharing options...
civicturbo79 Posted July 5, 2009 Share Posted July 5, 2009 gearbox building is a hard job and not for anyone that does not know what they are doing . and that comes at a price . just get a s80 box it will be cheaper. Link to comment Share on other sites More sharing options...
integraz Posted July 12, 2009 Author Share Posted July 12, 2009 has anybody fitted a s4c or a y21 gearbox in there mb6s as s80 are just to much for at the moment.so would it work well?? Link to comment Share on other sites More sharing options...
integraz Posted July 16, 2009 Author Share Posted July 16, 2009 guys just wanted to know if i change my final drive which will be from a integra uk spec 4.7,on my s9b would it make a big difference???need advice asap! Link to comment Share on other sites More sharing options...
Dave Posted July 16, 2009 Share Posted July 16, 2009 I'm not too clued up on gearboxes myself, but afaik, you would need to change more than the final drive to notice big differences in how the car performs. The main reason alot of mb owners go for the S80 is the simple fact it has a limited slip diff, and of course the gear ratios are a lot better than the mbs standard box. Maybe someone can confirm what the differences will be changing the final drive, but i reckon it'll only change top end (make it higher or lower?)Hope this helps a bit Link to comment Share on other sites More sharing options...
civicturbo79 Posted July 16, 2009 Share Posted July 16, 2009 A 1.8 vti mb6 has a lsd as standard , only aerodeck dont have it.The s80 box has lsd and shorter ratio's they say it knocks 1 second off the 0 to 60 on a mb6 over a standard box.as daves says changing the final drive will make the gears shorter or longer (meaning mph in each gear higher or lower) it will not change the ratio of each gear so you will still have that rubbish ratio between first and second that everyone hates. Rich. Link to comment Share on other sites More sharing options...
