B18C4 Engine hesitation and Idle fluctuation
Daniel
Hello there, I have an issue with my MB6 B18C4. The engine sometimes hesitates sometimes not and the car has very bad idling. It fluctuates a lot. New distributor, new TPS, new MAP, new IACV, new throttle body, new spark plugs and spark plug wires and the car has enough coolant in it. Any ideas?
  • 6 months later...
Haha i have the same problem... i have done almost all the same things. Im suspecting the coolant sensor under the distributor. But update if you find the issue!
  • 4 months later...
Have you tried cleaning out the vtec solenoid? Sometimes helps. Does it do it both when the engines cold or hot?
Another thing to check is fuel filter, most have probably never been changed so could be well past its best.
