johngreen537 Posted October 13, 2010 Share Posted October 13, 2010 GentsJust to clarify, do both EG & EK shocks & Springs bolt straight on to an MB6!That opens up many many more doors on ebay JohNG Link to comment Share on other sites More sharing options...
uzy Posted October 13, 2010 Share Posted October 13, 2010 yes they do. but you will need the EG/EK top mount nuts as the MB ones are different.also bare in mind that the EG/EK shocks and springs are from lighter cars so take that in accordance when purchasing your stuff Link to comment Share on other sites More sharing options...
KKND Posted October 13, 2010 Share Posted October 13, 2010 One more thing, the fork (i think it is the way to write) is diferent. Link to comment Share on other sites More sharing options...
MeisterR Posted October 14, 2010 Share Posted October 14, 2010 EK Coilovers can fit MB6.The front is the same as the EG / EK. The rear have the same fork size as the EK (40mm).However, because the MB6 standard rear suspension are longer than the EK, the range of height adjustment will not be correct. Link to comment Share on other sites More sharing options...
johngreen537 Posted October 14, 2010 Author Share Posted October 14, 2010 Might get some of the EK adjustable variety then...Gives me a bit of room to play then! Link to comment Share on other sites More sharing options...
MeisterR Posted October 14, 2010 Share Posted October 14, 2010 Might get some of the EK adjustable variety then...Gives me a bit of room to play then!Thats the point... if you get a set EK coilovers, you won't have any room to play with them.As most likely the highest point of adjustment will only be where it is acceptable on the MB6.You can get away a little using a Dual Perch Coilovers like MeisterR Zeta-S as you can adjust the ride height and the spring pre-load...On a single perch coilovers such as Tein Super Street... it will mean the rear springs will have be need to have massive amount of pre-load in them just to keep the ride height to what you need.In the end, it depends on what you are looking for.If you are looking for cheap drop, then the EK coilovers will "fit"; but it doesn't mean it will be "right" on the MB6. Link to comment Share on other sites More sharing options...
johngreen537 Posted October 14, 2010 Author Share Posted October 14, 2010 Fair comment. I'll get some cash together and do it properly Link to comment Share on other sites More sharing options...
cubchai Posted October 19, 2010 Share Posted October 19, 2010 Might get some of the EK adjustable variety then...Gives me a bit of room to play then!Thats the point... if you get a set EK coilovers, you won't have any room to play with them.As most likely the highest point of adjustment will only be where it is acceptable on the MB6.You can get away a little using a Dual Perch Coilovers like MeisterR Zeta-S as you can adjust the ride height and the spring pre-load...On a single perch coilovers such as Tein Super Street... it will mean the rear springs will have be need to have massive amount of pre-load in them just to keep the ride height to what you need.In the end, it depends on what you are looking for.If you are looking for cheap drop, then the EK coilovers will "fit"; but it doesn't mean it will be "right" on the MB6.I have a set of TEIN SS in...very disappointed...can't get my rear high enough. Hence, lowered front to match the rear. Just too low for me.Get some coilovers which fit MB6 directly will be better.BTW, anyway tips for me to jack up my rear? Link to comment Share on other sites More sharing options...
MeisterR Posted October 20, 2010 Share Posted October 20, 2010 I have a set of TEIN SS in...very disappointed...can't get my rear high enough. Hence, lowered front to match the rear. Just too low for me.Get some coilovers which fit MB6 directly will be better.BTW, anyway tips for me to jack up my rear?Hum... Tein SS coilovers huh...It depends on how the dampers are made... It is possible to maybe use a longer and stronger springs... However, that may mess up the vehicle dynamic, thats the problem with single perch coilovers... You can't separate the ride height adjustment from the spring adjustment, which mean you will affect the how the car ride when trying to adjust ride height.Let me know if you need some help...But to be honest, I would say it is better to sell the Tein coilovers to a EK and just buy a set of MeisterR Zeta-S that are design to fit and work on the MB6 to begin with... instead of trying to reinvent the wheel and fix something that isn't right to begin with. Link to comment Share on other sites More sharing options...
jonnyricer Posted October 20, 2010 Share Posted October 20, 2010 jerrick you is proper name dropping there he he good info therewhen funds allow ill be getting some of these bad boy meisters! Link to comment Share on other sites More sharing options...
