SteveMB6 Posted February 2, 2011 Share Posted February 2, 2011 Yeah piston rings for definate. I used 18 litres of oil in 6k miles before it was fixed.Its a day job really, me and a mate started at 9am and finished at 9pm. I would expect to pay around £250-£300 for labour alone.Gasket kit is £100 from part supplier (not oem Honda)Piston rings are £55 delivered from a guy on the ITR forums who rebuilts vtecs and races them.Here is a link to the thread - http://www.itr-dc2.com/forum/viewtopic. ... highlight=Then obviously you need new oil/oil filterWhile the head is off you should get the Valve Stem Oil Seals replaced too. They should come with the gasket kit.edit - oh and you may as well get a new timing belt on when building it all back up. Link to comment Share on other sites More sharing options...
jallen69 Posted February 2, 2011 Author Share Posted February 2, 2011 Yeah piston rings for definate. I used 18 litres of oil in 6k miles before it was fixed.Its a day job really, me and a mate started at 9am and finished at 9pm. I would expect to pay around £250-£300 for labour alone.Gasket kit is £100 from part supplier (not oem Honda)Piston rings are £55 delivered from a guy on the ITR forums who rebuilts vtecs and races them.Here is a link to the thread - http://www.itr-dc2.com/forum/viewtopic. ... highlight=Then obviously you need new oil/oil filterWhile the head is off you should get the Valve Stem Oil Seals replaced too. They should come with the gasket kit.edit - oh and you may as well get a new timing belt on when building it all back up.yea i used to be a vehicle tech so i should have a problem doing this, just wanted to know how much it's likely to cost, being a honda and all.... thanks for your helpjosh Link to comment Share on other sites More sharing options...
