Dave Posted February 12, 2011 Share Posted February 12, 2011 OK, this is a strange one, and could possibly just be my imagination. Was out in the MB6 the other day, and accelerated as we were joining a motorway. I'm almost certain that VTEC did not kick in in 3rd gear, and even said to dawn it felt slow. Then carried on our way, didnt think any more about it. Few days later, and same kinda scene, entering motorway (in 2nd) and accelerated down slip road. Vtec kicked in, then into 3rd gear, and watched the revs/listened to the sound as I hit 4.5k, no change? car felt like deff no vtec. Into 4th, felt the same, not the usual zoom!I've checked the oil, it's fine, and up to the mark. Just not sure if its possible to have vtec engage in one gear but not another? Or would it be all gears or none at all? Deff a strange one! Or could be i'm just too used to it now? Other days its quite obvious when VTEC is coming on Link to comment Share on other sites More sharing options...
Aky Posted February 12, 2011 Share Posted February 12, 2011 Sometimes I can't tell if vtecs kicked in at 4400k but DEFFO can tell at 6k. My old b18 used to loose oil pressure if I used anything apart from mobil1.Could give vtec solenoid a clean I suppose? Link to comment Share on other sites More sharing options...
simpo Posted February 12, 2011 Share Posted February 12, 2011 are you running any induction kits? i just got a long arm for mine and i am pretty sure mine doesnt work in 1st and sometimes second Link to comment Share on other sites More sharing options...
KiNK43 Posted February 12, 2011 Share Posted February 12, 2011 That is strange. But I have to concur.I also used to loose oil pressure. Changed to mobil 1. Problem solved. Link to comment Share on other sites More sharing options...
ryan.. Posted February 12, 2011 Share Posted February 12, 2011 i never notice till i hit jut under 6k. You'd never know it starts at 4.4k unless you knew is did Link to comment Share on other sites More sharing options...
johngreen537 Posted February 12, 2011 Share Posted February 12, 2011 Make sure your oil level is bang on top mark mate!'Iffy' VTEC is a classic sign that oil is starting to get below optimum! Link to comment Share on other sites More sharing options...
civicturbo79 Posted February 12, 2011 Share Posted February 12, 2011 If you have checked the oil , and there is no lights on the dash , Whwn was the last time you changed the oil and what did you use , vtec is controlled by the vtec solenoid / ecu and oil pressure so if the solenoid works it can only really be oil pressure , I would start by taken the vtec solenoid off there is only 10 mm bolts holding it on and them clean out the filter inside and why its off give it a 12v feed and make sure its working , if that does not work i would change the oil and filter . Rich. Link to comment Share on other sites More sharing options...
Dave Posted February 13, 2011 Author Share Posted February 13, 2011 she's due an oil change so suppose it could be that then. Just running standard airfilter etc at the moment. I'll take out the solenoid when im off work and clean it out. Need to get her in for a service now groan! Link to comment Share on other sites More sharing options...
shebabby Posted February 13, 2011 Share Posted February 13, 2011 mines same mate mainly wen i go down hill ?i put it down to engine preasure ie: down hill no ressistance there for no need ?i mite be wrong !!! Link to comment Share on other sites More sharing options...
johngreen537 Posted February 13, 2011 Share Posted February 13, 2011 OIL OIL OIL Dave, 'book' it in for a service? 17mm socket, and a filter wrench, only take 20 mins to do oil and filter Link to comment Share on other sites More sharing options...
