james Posted September 23, 2011 Share Posted September 23, 2011 i have a problem with it and need assistancei think its the motor or something Link to comment Share on other sites More sharing options...
noodels Posted September 23, 2011 Share Posted September 23, 2011 whats it not doing Link to comment Share on other sites More sharing options...
james Posted September 24, 2011 Author Share Posted September 24, 2011 cooling Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted September 24, 2011 Share Posted September 24, 2011 If you are idling, and you put the aircon on does the exhaust sound change? Link to comment Share on other sites More sharing options...
james Posted September 24, 2011 Author Share Posted September 24, 2011 yep Link to comment Share on other sites More sharing options...
noodels Posted September 24, 2011 Share Posted September 24, 2011 well that means the relay is kicking it in then,any pressure in system,may have lost it ?when did it last work? Link to comment Share on other sites More sharing options...
james Posted September 24, 2011 Author Share Posted September 24, 2011 never Link to comment Share on other sites More sharing options...
noodels Posted September 24, 2011 Share Posted September 24, 2011 prob need a regas then. Link to comment Share on other sites More sharing options...
james Posted September 25, 2011 Author Share Posted September 25, 2011 dont know but i will find out Link to comment Share on other sites More sharing options...
johngreen537 Posted September 26, 2011 Share Posted September 26, 2011 Only way to find out mate is to take it to get refilled.... They can also put in a dye, which will show under UV light if any gas is leaking so you can get it repaired.AirCon is expensive when it goes Pete Tong though! £60 ish to regas, then if its not gas, fix, then refill (again £60) hope it works, if not fix next bit and refill... again paying.Take it off... Thinke the weight of the compressor, rad and all hoses are near on 30kgs! 30kgs less = MORE Link to comment Share on other sites More sharing options...
