andrew1 Posted October 21, 2011 Share Posted October 21, 2011 Hi i need a bit of advice on my 98 1.4 SE MB2 , the idling is a bit erratic expecialy when cold it jumps between 7 and 4000 revs also it happens now and then when the engine is warmed up . I have googl'ed it but as usual various answers , the car has been serviced and all the belts have been changed about 4000 miles ago i noticed also it uses oil but not leaking anywhere and it's not smoking under acceleration but stinks of petrol if i accelerate hard , If i take the oil cap off while the engine is running it has what you could say (blow back ) is this normal ?? i read somewhere if this is the case then the rings are gone Please guys any help on these problems thanks Link to comment Share on other sites More sharing options...
Steve-P13 Posted October 22, 2011 Share Posted October 22, 2011 I had a similar problem mine was reving all by itself between 1500 and 3500 revs, was a valve/control unit thing think its call the AIVC valve located under the throttle body. I took it off and cleaned with brake cleaner however this did not solve the problem, so got a second hand one from my local scrap yard and that solved it hope this helps. Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted October 22, 2011 Share Posted October 22, 2011 Always worth trying that first though Link to comment Share on other sites More sharing options...
james Posted October 22, 2011 Share Posted October 22, 2011 sounds like that vale is at fault allright ... have a lookas for the blow back yea thats trough but how bad is it Link to comment Share on other sites More sharing options...
andrew1 Posted October 22, 2011 Author Share Posted October 22, 2011 Thanks guys will have a look in the meantime i got a quote from honda in southport £325.95 and that's excluding fitting@ james blowback seams pretty bad. but she doesn't smoke ?? Link to comment Share on other sites More sharing options...
Steve-P13 Posted October 23, 2011 Share Posted October 23, 2011 Is that quote for the AIVC valve?!?!? I only paid 30 quid from a breakers and it takes 20 minutes to fit Link to comment Share on other sites More sharing options...
andrew1 Posted October 23, 2011 Author Share Posted October 23, 2011 Is that quote for the AIVC valve?!?!? I only paid 30 quid from a breakers and it takes 20 minutes to fityep that's just for the AICV valve Link to comment Share on other sites More sharing options...
noodels Posted October 23, 2011 Share Posted October 23, 2011 thought it was called IACV Link to comment Share on other sites More sharing options...
andrew1 Posted October 23, 2011 Author Share Posted October 23, 2011 thought it was called IACVi mean the IACV Link to comment Share on other sites More sharing options...
