MeisterR
£100 Off MeisterR Coilovers until 31/12! Code: MB100
We are offering MeisterR Coilovers at £100 OFF for Civic5 Members until 31st of December.
The Specification of the Zeta-R Coilovers:
*Aluminium Top Mount with Pillowball Bearing.
*Monotube damper with 32 stage damping adjustment (Compression and Rebound Combined)
*Linear Rate SAE9254 Chrome Silicon Steel Springs
*Lengthen Heavy Duty Rubber boot.
*Aluminium Spring Perch, Locking Collar, and Lower Bracket
*Dual Perch Coilovers Construction
ED / EF
Zeta-S (RRP:£649): £549.00 + P&P
EG / EK / DC2
Zeta-S SuperLow (RRP: £699): £599.00 + P&P
Zeta-R (RRP: £699): £599.00 + P&P
MB (Sedan / AeroDeck)
Zeta-S (RRP:£699): £599.00 + P&P
EP2 / EP3 / DC5 / FD2 / FN2
Zeta-R (RRP:£729): £629.00 + P&P
How to order? Price?
Ordering couldn't be easier. Simply place your order at the MeisterR website ( http://www.MeisterR.com ) and check out using the secured webshop.
All you have to do is enter the voucher code below during checkout and your discount will be automatically calculated.
Just put in the voucher code MB100 during checkout to get your Discount!
If you have any problem, please feel free to PM me or E-mail me at info@meisterR.com
We also have a range of CyberSpeeds accessories such as 286mm Front Brake Upgrade, Rear Lower Control Arm, Front Camber Arm, Rear Camber Arm, Rear Toe Arm, Roll Centre Adjuster, etc.
All accessories purchased with the coilovers will receive free shipping.
A Few Pictures of the Coilovers and cars with the MeisterR Coilovers Installed.
MeisterR Zeta-R (EG / EK / DC2)
MeisterR Zeta-S (EF / EG / EK / DC2 / MB6)
MeisterR Zeta-R (EP3 / DC5)
A few awesome pictures of DC2 on MeisterR Coilovers:
MeisterR Zeta-S on CRX
MeisterR Zeta-S on EG
MeisterR Zeta-S SuperLow on EJ
MeisterR Zeta-S on AeroDeck
MeisterR Zeta-R on EP3
Share this post
Link to post
Now thats quality kit! 8-)
Share this post
Link to post
how much do they lower your by
Easily 100mm on the MB.
To be honest, lowering alot on the MB isn't the problem.
It is giving it enough adjustments so the car isn't completely slammed.
But let me know what you want and I am happy to give you suggestions.
Share this post
Link to post
The point of coilovers is that they are fully adjustable, so you can go from standard ride height to very low :D
Share this post
Link to post
im wanting abt 30-40mm drop suitable ride for everyday use
Yep, the Zeta-S for the MB6 should have no problem doing that. :)
What you will find is that most coilovers cannot do that on the MB6.
The main reason is most coilovers are EK coilovers "fitted" to the MB6, and not specifically designed like the MeisterR Zeta-S
Because of that, the "highest" you can set the ride height is something like -80mm or so... and you end up with the choice between low and really really low.
Share this post
Link to post
