Front passenger side fog light not working???
Nemesis
sounds like the bulb might have popped yes.
To remove you need to undo the 4 screws holding the bottom cover. These are notoriously hard to remove as the screws are made of chocolate.
Once you take the plate off you unclip the spade connector then unclip the metal prong holding the bulb in place and pull the bulb out.
The bulb is a H3
Obviously fitting is the reverse
