De-cat size?
Paulvti
2.25" decat UK length.
Don't think there is a 2" as such.
Manifold flanges are usually all a 2.25" joint or the JDM/ aftermarket 2.5"
Piping on the 2.25" decat will be nearer 2" most of the time.
Just fit your manifold with a 2.5 decat. Pretty much All 2.5 decats run 60mm piping anyways which is only about 2.35". As long as your center flange 3 holes line up as they should then a 2.5" (2.35" reality) decat will be fine.
Otherwise get a 2.5 decat cut and stepped down to 2.25 at the center entrance either way you will have s step from manifold to center. Unless you stick with a. Standard sized manifold 2.25" which is dump.
Soooo where do I get an adjustable 2.5" de-cat pipe from?
I can't find any, I don't mind buying a none adjustable one but they are apparently always the wrong length....
