What cams did you put in on that setup, are there certain cams I should avoid? And ECU wise what’s generally recommended?
I know lots of questions but just trying to get an idea together of what’s worth doing on it for when I manage to give back this Mercedes I’m currently stuck with! banghead.gif1
  • 3 weeks later...
I project (<<<<< see what i did there!)that theres a lot more than a clean up happening here! Looking forward to seeing these getting done mate.
Cheers @dr_broon they haven’t come up too bad... but as boss man @Dave stated... a lot more going on here... I have one lamp apart and reflector cut to size to fit the projector in... just to work out how fix it in place, and then to work out the electrics of them.
photos to come...
on @EmZvr‘s how too he mentions the importance of keeping the reflective shroud pristine... but I powered the projector unit up on its own in front of our beam setter at work, and pattern and intensity seemed perfect... to I actually HAVE to keep the reflective housing chromed up or could I get away with blacking it out??
Done some research into the reflectors... found out that the reflective bowl that is fitted within the projector lamps themselves is all it needs... so good bye chrome shrouds!! Started the de chromeing process today!!
