Good afternoon, I am the owner of a 1996 Honda Civic MA from Ukraine and I have such a not very typical problem. I have problems with the ABS unit. What exactly is not typical, you ask? And the fact that I cannot find such an abs unit. In 1995, abs with a tank were installed, and in 1996 they looked completely different than in the photo I attached. Also, the problem is that for checking it is necessary to connect not 1-3 pins of the 5-pin connector, but the one under the steering wheel near the fuses. When searching for information, the most similar ABS units were found on the ROVER 600 and Accord 5, where in the latest versions of this ABS unit, they were also checked by shorting the connector under the steering wheel instead of the 5-pin connector. Please explain to me, as a beginner, what kind of equipment this car has (disc brakes from the back and front, D14A2 engine). Maybe error 81 in such a unit does not mean the breakdown of the abs unit itself, but something else? If not, then I will try to connect the ABS unit with the Accord 5 that I bought in my country.
Question
Andrei_Ma1.4
1 answer to this question
