cams
Guest kev21
Guest AccessoryZone
EK9 cams are really good upgrade for a B16 or B18.
Not as good as ITR cams would be though but still good.
There are other options out there though. You could go with Blox Racing cam's. These are direct replicas of the Skunk 2 Stage 2 cams. These make some good power but you would need new valve springs for anything aftermarket.
there are many management systems out there from £100-£600+
The best systems are the stand aloan management systems like the hondata s300
you will need a p28 or pr4 ecu to fit that in a mb6 and then get it mapped, that is about £350 + vat
Total around £800 ish from management + map.
