Guest kev21 Posted August 7, 2009 Share Posted August 7, 2009 hi everyone need help been looking at cams on funklypower any1 used ek9 cams ment to be really good Link to comment Share on other sites More sharing options...
Guest AccessoryZone Posted August 8, 2009 Share Posted August 8, 2009 EK9 cams are really good upgrade for a B16 or B18. Not as good as ITR cams would be though but still good. There are other options out there though. You could go with Blox Racing cam's. These are direct replicas of the Skunk 2 Stage 2 cams. These make some good power but you would need new valve springs for anything aftermarket. Link to comment Share on other sites More sharing options...
Guest kev21 Posted August 8, 2009 Share Posted August 8, 2009 ok thanks itr cams how much and how much power they add Link to comment Share on other sites More sharing options...
civicturbo79 Posted August 8, 2009 Share Posted August 8, 2009 With any mod like that you will have to get it mapped to get the most out of it.Rich. Link to comment Share on other sites More sharing options...
Guest kev21 Posted August 8, 2009 Share Posted August 8, 2009 ok thanks do you kw now much mapping is Link to comment Share on other sites More sharing options...
Moe Posted August 8, 2009 Share Posted August 8, 2009 it all depends on what management you are using. ring around a few places and get some quotes Link to comment Share on other sites More sharing options...
civicturbo79 Posted August 8, 2009 Share Posted August 8, 2009 there are many management systems out there from £100-£600+ The best systems are the stand aloan management systems like the hondata s300 you will need a p28 or pr4 ecu to fit that in a mb6 and then get it mapped, that is about £350 + vat Total around £800 ish from management + map. Link to comment Share on other sites More sharing options...
integraz Posted August 9, 2009 Share Posted August 9, 2009 sorry to jack your thread,just a question i thought the b16b cams are better as they are more aggressive in vtec. Link to comment Share on other sites More sharing options...
Guest kev21 Posted August 9, 2009 Share Posted August 9, 2009 are they striaght swap b16b cams Link to comment Share on other sites More sharing options...
Guest kev21 Posted August 9, 2009 Share Posted August 9, 2009 aint b16b cams ek9 Link to comment Share on other sites More sharing options...
