tontvti Posted July 15, 2010 Share Posted July 15, 2010 I didn't, Just turned it off and back on straight away.Get the car warm before you do the reset otherwise the car will be in cold start mode and will dump more fuel in when you first turn it on. Link to comment Share on other sites More sharing options...
SteveMB6 Posted July 15, 2010 Share Posted July 15, 2010 cheers Link to comment Share on other sites More sharing options...
SteveMB6 Posted July 16, 2010 Share Posted July 16, 2010 I did this last night, to be honest i didnt notice any difference apart from the smoother idle. Link to comment Share on other sites More sharing options...
tasis Posted September 3, 2010 Share Posted September 3, 2010 Hello dudes, I just wanted to ask, if my MB2 has the same ECU as the MB6s.I want to fit a hi-flow cat, rear silencer,4-1 manifold, hi-flow air filter,new spark plugs and leads, clean up the injectors,change fuel filter, adjust valves and change oil and filter. For maintence, I don't think that I have to reser my ECU. But for the rest, if I reset it, is the ECU self-programming and does alone fine tuning?Or after fitting exhaust etc, I need to reprogrammed it manually, with a laptop on a dyno ?One more question.Does anyone knows, if my ECU has OBD port?Thank you for your advises.Tasis. Link to comment Share on other sites More sharing options...
