typertony Posted September 13, 2009 Share Posted September 13, 2009 I have a b18c4 and an looking to change the inlet manifold for a single runner type.Other that the inlet manifold, what else needs to be changed? loom or ecu?also what gains have people seem from this mod?cheerstony Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 13, 2009 Share Posted September 13, 2009 Dont do it unless you want to spend big money, you will need a single stage set of cams and valve train and management to run it all,You will get the same gains from a good exhaust and filter . every mb6 i no that has changed the standard manifold has put it back on because the could not get them to run right ( i one of them ) . Rich. Link to comment Share on other sites More sharing options...
uzy Posted September 13, 2009 Share Posted September 13, 2009 yes whatever rich said he knows his stuffs Link to comment Share on other sites More sharing options...
G Unit Posted September 13, 2009 Share Posted September 13, 2009 you dont require to change cams and valvetrain but you do need a remap with the ecu and as rich said a few members running them had a few issues but it can be resloved with some mapping Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 14, 2009 Share Posted September 14, 2009 This is were the problems start if you just fit the inlet, The rest of the engine is set up for the twin stage. (coursing flat spots) . The cams have to be changed due to them being made to come on vtec at 4500 rpm .So to get the most out of your single stage change them for a 6000 rpm vtec set up (ie like the skunk 2's ) and at that point as you are opening the valves more you are best to change the valves and retainers to ones that are made to handle it.Then with you management you can move the limiter to 9000 rpm = more power . Last thing you want after all that work is something in the vavle train to break and it will be an engine rebuild.Always best to go over the top than not to do enough and have something break. Rich. Link to comment Share on other sites More sharing options...
G Unit Posted September 14, 2009 Share Posted September 14, 2009 hmm im under the impression that its controlled via vtec solinod and ecu setting for the vtec engadment point.regaurdless tho you still need a remap for best results when fitting the skunk2 manifold Link to comment Share on other sites More sharing options...
megamitzmb6 Posted September 18, 2009 Share Posted September 18, 2009 are the later mb6's not already equipped with dual valve springs etc, iirc i heard the ones in the b18c4 are the same a ITR ones. Link to comment Share on other sites More sharing options...
