MG ZS LHD rack fitment
E=MC2
as i said in a topic subject, i am considering the purchase of LHD ZS rack, because as i found, ZS rack is much faster (1.9 lock to lock instead 3.5 as it is on MB/MC)
subframe mounting should be the same acording to pictures, but i am would like to know will LHD MC2 piping fit straight to ZS rack
  • Replies 26
Top Posters In This Topic
...thinking more about this, if they were different could you not just cut the piping & use some 8mm brass compression fittings to connect them together at some point? Something like this:
http://www.lsengineers.co.uk/metric-bra ... e=googleps
You'd be able to get similar connectors to go from one pipe diameter to another too.
Connectors would not be problem, it can be done. Bolt on or with small intervention, but it can be sorted out
What i am interested in is that i don't know will be some fitment problems such as subframe mount points, steering column point, power steering pump...
ZS rack is evolved civic rack, so i think that everything should be the same, but that is just my presumption
