np63om Posted April 25, 2012 Share Posted April 25, 2012 hello nice people, i really need your best help, i mean, i need to change for new one, i my think this is the right name of it, it call: Articulation axial coupling barIt is on civic MA8...is the one make tha car tuns the wheels, when we turn steering wheel, i need to change to new one, the left site is a little loose, my concern is to change it, it just unscrew the old one and place the new one,no oil or anything came out or leak out? Of course then, after that i must align the direction, it is that so simple?? Please, help really.Regards Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 30, 2012 Share Posted April 30, 2012 It sounds like you are talking about the front track rod ends . you just need to undo the lock nut and unscrew the track rod end no oil will leak out . count the turns you unscrew it and put the new ones on the same amount of turns . then get the tracking checked . Rich. Quote Link to comment Share on other sites More sharing options...
np63om Posted May 21, 2012 Author Share Posted May 21, 2012 civicturbo79 said: It sounds like you are talking about the front track rod ends . you just need to undo the lock nut and unscrew the track rod end no oil will leak out . count the turns you unscrew it and put the new ones on the same amount of turns . then get the tracking checked . Rich.My best best REGARDS, for your help, it realy help it.Regrads on more time!! Quote Link to comment Share on other sites More sharing options...
