mb2 wont start
Hop78
just fitted a new vehicle speed sensor, started it up worked ok drove it, i noticed when i started it up the green key immobiliser light flashed longer than normal, turned the car off then tried turning it back on and the car wouldn't start, electrics work, all the lights come on the dash apart from the immobiliser light, all you can hear under the bonnet is the relay click thats it, when i opened the bonnet the 3 wires from harness to the vss which are lose (previous owner cut the plug off the harness) two of them were touching.
not sure if ive blown the alternator, starter motor or the ecu.
ive checked all the fuses, all seem ok
tried bump starting, sounded like it was trying, but couldnt manage it
  • 4 weeks later...
