Hop78 Posted March 12, 2013 Share Posted March 12, 2013 just fitted a new vehicle speed sensor, started it up worked ok drove it, i noticed when i started it up the green key immobiliser light flashed longer than normal, turned the car off then tried turning it back on and the car wouldn't start, electrics work, all the lights come on the dash apart from the immobiliser light, all you can hear under the bonnet is the relay click thats it, when i opened the bonnet the 3 wires from harness to the vss which are lose (previous owner cut the plug off the harness) two of them were touching.not sure if ive blown the alternator, starter motor or the ecu.ive checked all the fuses, all seem oktried bump starting, sounded like it was trying, but couldnt manage it Quote Link to comment Share on other sites More sharing options...
Raz s Posted April 3, 2013 Share Posted April 3, 2013 Sounds like the immobiliser has kicked in to me. Quote Link to comment Share on other sites More sharing options...
