Guest Posted January 25, 2010 Share Posted January 25, 2010 need to change the pads on the back of the Civic, I don’t have the tool for winding the pistons back in.Will a large screwdriver suffice? Link to comment Share on other sites More sharing options...
civicturbo79 Posted January 25, 2010 Share Posted January 25, 2010 Yes mate that will be fine just put on pressure as you turn . Rich. Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2010 Share Posted January 25, 2010 Thats great thanks Link to comment Share on other sites More sharing options...
shaft32 Posted January 25, 2010 Share Posted January 25, 2010 make sure you turn it the right way or the piston will pop out if that doesnt work unscrew the bleeding nipple to releive the preasure when turning the piston. you might need to bleed the brakes after it Link to comment Share on other sites More sharing options...
