birneyboy Posted March 27, 2010 Share Posted March 27, 2010 had my mb6 lying up a wee wile and now my altenator has decided to sieze, whats handiest way to get it off as i can help but notice it doesnt look easily accessable! Link to comment Share on other sites More sharing options...
civicturbo79 Posted March 27, 2010 Share Posted March 27, 2010 Its not to bad mate ,There is onlt 2 bolts holding it on ,just a tight space thats all ,its harder to change the belt than the alternator. make sure you disconnect the battery . Link to comment Share on other sites More sharing options...
birneyboy Posted March 27, 2010 Author Share Posted March 27, 2010 whats handiest way at it? from above or below? Link to comment Share on other sites More sharing options...
stubrun Posted March 27, 2010 Share Posted March 27, 2010 both, but i did mine from above Link to comment Share on other sites More sharing options...
civicturbo79 Posted March 27, 2010 Share Posted March 27, 2010 You need to disconnect the battery , go under to disconnect the wires to the alternator , loosen off both bolts from the top , To remove the belt from the alternator ,then remove the top bolt, back under to remove the bottom bolt and drop the alternator down , do this in reverse to fit the new one . Rich. Link to comment Share on other sites More sharing options...
birneyboy Posted March 29, 2010 Author Share Posted March 29, 2010 thanks rich ! Link to comment Share on other sites More sharing options...
