birneyboy Posted April 11, 2010 Share Posted April 11, 2010 hey i got myself a set of ngk leads and im thinking ngk plugs will work best with those, whats best performance plugs? what are you using? you find any difference? Link to comment Share on other sites More sharing options...
stapi Posted April 12, 2010 Share Posted April 12, 2010 I have done a bit of a research about that myself recently, most sources generally say that a sparkplug is just a sparkplug and there is not much difference between them. The fact is that some of them are a bit better quality and will last longer but you can’t really expect any difference in ‘performance’ (please correct me if I’m wrong). I ended up buying DENSO Iridium, I’m happy with them, but to be honest can’t see any difference compared to standard NGK ones I had fitted previously. Link to comment Share on other sites More sharing options...
MBBREAKERS Posted April 12, 2010 Share Posted April 12, 2010 i have run for the last 5 years i think the same make of plugs and they arent mega money bosch super 4's about £20 for set in halfords , there is 4 tips on the end of the plug so engine always gets the most powerful spark availble Link to comment Share on other sites More sharing options...
birneyboy Posted April 12, 2010 Author Share Posted April 12, 2010 any other thoughts? Link to comment Share on other sites More sharing options...
david974 Posted April 13, 2010 Share Posted April 13, 2010 Ngk BKR7 for hard driving iridium or copper it's just a story of life span and Iridium are not cheaphttp://www.amazon.com/NGK-BKR7E-Spark-P ... B000COTOZ6http://cgi.ebay.fr/4-Bougies-NGK-Iridiu ... 0548895804I prefer to spent 4 set of 4 normal spark plug it would be less expensive than IrridiumIn my car i run NGK Racing number 7 or 8 non resistor ones and also nonprojected tip http://www.summitracing.com/parts/NGK-4 ... t=NGK-4554the impotant is that you must have the good Heat Rangeregards Link to comment Share on other sites More sharing options...
