  • 0
Engine wont start
armin81
Hi,
My Civic MB8 '98 wont start. Bought in august with fault that the engine did not work. Previous owners had also problems with fuel pump, which has been replaced.
Engine wont start although the green immo key goes out, the engine cranks but no spark and I cant smell petrol (possibly no signal to the injectors?).
Trobleshooting with the help of the service manual was no success until I found that the ecu has been fried. Looked for a new one.
The engine is a D14A7 - 1.4 petrol with 55kw.
I got a second hand ecu possibly from an MA model '96. The engine was 1.4 petrol 66kw. Engine wont start although the green immo key goes out, the engine cranks but no spark and I cant smell petrol (possibly no signal to the injectors?).
Thinking that there would be immo problem tried to replace the immo chip (found later the article that it doesnt work). Tried also desoldering the immo chip. Nothing changed. Green immo key goes out and engine only cranks.
Next I got a set of everything: key, immo unit, ecu from an MA9 '96 (have the complete car. it was driving). Engine is 1.5 petrol vtec-e 66kw. All three things changed and engine olny cranks. It cant be immo related?
If i have a matching immo unit and the key AND any ecu - fuel pump primes, green immo key goes out, engine cranks but still no spark.
I think that I have checked all the fuses from under-dash and under-hood fuseboxes.
The under-dash fusebox has different connectors. Tried to change that.
I have a D14A4 on my EJ9. It's OBD2a and has the same dizzy. Both Dizzy's work on the EJ9. But the MB8 is missing 5V for the TDC (has only 0,8V). Measured directly from ecu output.
Any ideas what am I missing?
  • 0
Hi Everyone.
Did anyone know that the wiring in the MA8/MA9 and MB8/MB9 is slighlty different?
So now I accidently found a service manual for MA model. It was in 95 year folder and I didn't pay attention to it. Until today.
First I compared the wiring and remembered that the EG/EJ wiring is similar. I have earlier compared an P28 ecu (92-95 EG/EJ) pin-out to my MB8 pin-out. I have a D16Z9 engine waiting and I tried the P28 ecu. which also didn't work. Different plug etc. From ~50 wires I found matching only 5!
Later I noticed that the numbering system for the plugs is totally different.
In some manuals the count through the rows and in other manuals they count through columns. So I transfered the positions to a new system. And the picture is much better now.
Until now I was troubleshooting with the manual for the MB. That's why everything checks out.
Now I'm making final notes to what wires I have to change to make it work for the MA ECU.
wiring count.pdf
wiring.pdf
Answer this question...
