  • 0
Engine wont start
armin81
Hi,
My Civic MB8 '98 wont start. Bought in august with fault that the engine did not work. Previous owners had also problems with fuel pump, which has been replaced.
Engine wont start although the green immo key goes out, the engine cranks but no spark and I cant smell petrol (possibly no signal to the injectors?).
Trobleshooting with the help of the service manual was no success until I found that the ecu has been fried. Looked for a new one.
The engine is a D14A7 - 1.4 petrol with 55kw.
I got a second hand ecu possibly from an MA model '96. The engine was 1.4 petrol 66kw. Engine wont start although the green immo key goes out, the engine cranks but no spark and I cant smell petrol (possibly no signal to the injectors?).
Thinking that there would be immo problem tried to replace the immo chip (found later the article that it doesnt work). Tried also desoldering the immo chip. Nothing changed. Green immo key goes out and engine only cranks.
Next I got a set of everything: key, immo unit, ecu from an MA9 '96 (have the complete car. it was driving). Engine is 1.5 petrol vtec-e 66kw. All three things changed and engine olny cranks. It cant be immo related?
If i have a matching immo unit and the key AND any ecu - fuel pump primes, green immo key goes out, engine cranks but still no spark.
I think that I have checked all the fuses from under-dash and under-hood fuseboxes.
The under-dash fusebox has different connectors. Tried to change that.
I have a D14A4 on my EJ9. It's OBD2a and has the same dizzy. Both Dizzy's work on the EJ9. But the MB8 is missing 5V for the TDC (has only 0,8V). Measured directly from ecu output.
Any ideas what am I missing?
  • 1
as said above. make sure the earth from the battery is a good one, we had it on one of our mates cars. the earth wasn't good, it would spark, then no spark.
Honda's hate bad earths!
had it with mine, painted the bay. drove it 10 miles, turned the car off. went to start and had some problems as you until i scratched away some paint and made a better earth
  • 0
Might be worth checking the main relay that runs the fuel pump? I know the Eg's used to have problems with these, down to a dry solder joint inside the relay.
  • 0
Thanks for the answers. I replaced the main relay also with a known good one. Nothing changed.
Next up is the wiring. Waiting now for the weekend to have a chance to keep digging.
  • 0
So. I was checking the car in the weekend.
Tried different ignition switch.
Changed 3 underhood ground terminals, and checked with a tester the ground wires at ecu connectors. Also couldn't find any loose grounds under-dash.
Visiting a dealer might be the best option? How much data can they read from ecu? I have heard that OBD2 gives more data. But they should be able to diagnose the problem.
  • 0
I have no troublecodes.
Actually I paid a visit to the dealer. They tried sorting the problem for 4 hours and didn't find anything useful. They concluded that the ecu is bad/locked or smth. They couldn't access it. Tried to teach something, but I'm not sure what.
Anyway. I was dissappointed. Estimated time was 2 hours and they didn't call me before they had been working for 3,5 hours. And claimeing the ecu is bad.
I put everything back on the MA9 and it started on the first try.
More and more I'm thinking on the wiring. Has Honda changed some wires between MA and MB? Or shall I install MA9 underdash wiring in MB8 car?
  • 0
Hi Everyone.
Did anyone know that the wiring in the MA8/MA9 and MB8/MB9 is slighlty different?
So now I accidently found a service manual for MA model. It was in 95 year folder and I didn't pay attention to it. Until today.
First I compared the wiring and remembered that the EG/EJ wiring is similar. I have earlier compared an P28 ecu (92-95 EG/EJ) pin-out to my MB8 pin-out. I have a D16Z9 engine waiting and I tried the P28 ecu. which also didn't work. Different plug etc. From ~50 wires I found matching only 5!
Later I noticed that the numbering system for the plugs is totally different.
In some manuals the count through the rows and in other manuals they count through columns. So I transfered the positions to a new system. And the picture is much better now.
Until now I was troubleshooting with the manual for the MB. That's why everything checks out.
Now I'm making final notes to what wires I have to change to make it work for the MA ECU.
wiring count.pdf
wiring.pdf
Answer this question...
