Larry041 Posted May 10, 2010 Share Posted May 10, 2010 Hello,Has anyone tried to swap D14A2 to D16y3,Engines are quiet similar, so the question is,Do I need to change only block or engine head and ECU also necessary?Thanks in advice, Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2010 Share Posted May 11, 2010 covert your harness to OBD1engine mounts are finegearbox and shafts should be fine but d16 is better Link to comment Share on other sites More sharing options...
Larry041 Posted May 11, 2010 Author Share Posted May 11, 2010 I have ECU p17, hasn't it OBD1?And what kind of pars are different in these two?I think, if change only bock, fuel sprays and may be ECU, engine will become D16y3japcarmad, as I see you have mb1, your second gear shifts also slow, or it is only MA8 sickness? Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2010 Share Posted May 11, 2010 sorry i misread your question i thought you said d16z6.yeh your right. Link to comment Share on other sites More sharing options...
Larry041 Posted May 11, 2010 Author Share Posted May 11, 2010 Than should I change ECU or they are similar?And what about gearbox?I heard that Rover has the same Honda engine (d16y3), but it looks like different,Different is only head cover or something else? Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2010 Share Posted May 11, 2010 you will need to change the ecu. the rovers engine only has a different rocker cover i think.im sure the d14 gearbox will fit. Link to comment Share on other sites More sharing options...
Larry041 Posted May 11, 2010 Author Share Posted May 11, 2010 Just change ECU? wires are the same? Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2010 Share Posted May 12, 2010 im not sure the connections are the same you might need a harness converter. Link to comment Share on other sites More sharing options...
