s88hon Posted May 25, 2010 Share Posted May 25, 2010 So you cant get good power unless you get good pistonsDepends what your goal is.. If you want pure NA power that will easily beat tegs then I suggest pistons, cams and proper mapping = bucksIf you want to start slowly, first upgrade is cams, then followed by MAPPING! its very important to adjust them to optimal timing. I spent 3 hours on the dyno adjusting my cams / degree power run by power run.. Link to comment Share on other sites More sharing options...
s88hon Posted May 25, 2010 Share Posted May 25, 2010 i reckon a big fat turbo or super charger mate Thats the easy way out Link to comment Share on other sites More sharing options...
s88hon Posted May 25, 2010 Share Posted May 25, 2010 so what can be done to the d series engines compared to a b?As said.. Turbo but then again, alot of people we know ditched the D series and put a b series in, albeit B16 or B18 Link to comment Share on other sites More sharing options...
shaft32 Posted May 26, 2010 Share Posted May 26, 2010 i tried to get my d15z8 ecu remapped but cant,went to falkland performance and they said they cant do it to that type of ecu????????? 1"£££$££"! 1"£££$££"!! 1"£££$££" Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 27, 2010 Share Posted May 27, 2010 You can fit a piggy back ecu to may car with a ecu and then just map that . Rich. Link to comment Share on other sites More sharing options...
pikeypadfield Posted May 28, 2010 Author Share Posted May 28, 2010 ok like a dpt chip on a diesiel in which is a piggy back inbetween jobby it goes between the fuel pressure reg on common rails and on map sensor on pd's? anyone have any prices on cams and things for d's also how can i get good fuel economy. obv turbo gives a better volumetric efficiency due to forced inductionsaslong as u dont blow it everywhere. Link to comment Share on other sites More sharing options...
