IceMan Posted June 23, 2009 Share Posted June 23, 2009 My amp keeps blowing fuses nearly instantly after turning the ignition , and stranger still the power light remains lit!!! I have changed the earthing point but to no avail. Why would the power light remain lit after the fuse has blown ? Strange.Thing to note would be that it was working 8 months ago fine. Since then it had been left in the boot as the car was off the road while I ran the 200sx. I have moved the earth point because i noticed some rust.Cheers Link to comment Share on other sites More sharing options...
IceMan Posted June 23, 2009 Author Share Posted June 23, 2009 Just been googling this query and its leaning toward the amp being at fault. would make sense I guess as I haven't touched the wiring in 8 months. Amp probably got damp, frozen and heated up during winter and "summer" Link to comment Share on other sites More sharing options...
mc2vtimatt Posted June 23, 2009 Share Posted June 23, 2009 I was gonna say sounds like a knackered amp to me, bummer! Link to comment Share on other sites More sharing options...
IceMan Posted July 4, 2009 Author Share Posted July 4, 2009 UPDATE - so close yet so far...Got my amp repaired by the electrician in work. Now my sub pops when it gets powered up , when you run music through it its not as noticeable. If i set the amp to hi it makes a loud sharp noise. So its set lo for now. The only thing that has changed since it last worked fine is I have moved the earthing point, could this be it?Any ideas ? Link to comment Share on other sites More sharing options...
G Unit Posted July 4, 2009 Share Posted July 4, 2009 replace amp for a known working amp to see if this cure the issue then if its still the same chance the sub for a known working one , and for the last try re do the wiring!good luck Link to comment Share on other sites More sharing options...
