pikeypadfield Posted May 22, 2010 Share Posted May 22, 2010 ok just curious i have a mb3 i believe 1.5 vtec. just a few questions..what ecu is the best for this fueling and performance wise?would a d16 ecu work?i only ask this due to i had a 1.5 lsi with some sort of import ecu with better fuelling and other bits n pieces. Link to comment Share on other sites More sharing options...
Guest Posted May 22, 2010 Share Posted May 22, 2010 you might. just make sure the obd is the same or you will need a conversion harness. you will prob also need the fueling system from the d16.goto d-series.org and ask in there. Link to comment Share on other sites More sharing options...
pikeypadfield Posted May 22, 2010 Author Share Posted May 22, 2010 ok cheers matey Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 22, 2010 Share Posted May 22, 2010 You cannot just take an ecu from another car and fit it to yours ,well you could if you do not like you engine in one piece that is , if you are wanting to have the car mapped you need to get a piggy back ecu or a stand alone replacement ecu such as hondata s300 and have it mapped to your car and the mods you have . Rich. Link to comment Share on other sites More sharing options...
