  • 0
ABS Light and Parking Brake Light On
JPRafael
Hello there,
I've got a 1999 Honda Civic Aerodeck 1.6i SR (D16W4) and since today I've started witnessing a weird issue regarding the ABS. Basically I was heading home when suddenly my ABS and parking brake light came on shortly after entering a cobble stones road and it stood that way until I finally got home. After that I've turned my vehicle off and let it rest for like an hour. I then returned to the car and noticed that both the lights were off after i started the car. After driving for a few minutes (like 5 minutes) the lights came back on and stood that way for the remaining part of the journey. After that that I've tried to identify potential error codes. i bridge 2 pins in the Data Link Connector (5P), however there were no error to be seen whatsoever and the lights stood on the all time. I then turned the car off once again and let it rest for an hour and just like before, when I got back and started the car, the lights were off. With that being said I've tried slamming the brakes to make sure my ABS was indeed working which it was. After successfully stopping the car with a fully working ABS system, the two lights came back on.
After browsing my car's digital service manual (1999 version available on this site) i noticed that my vehicle is equipped with EDB. And according to the manual, if there's an issue regarding the EDB the parking brake light is supposed to come on followed the ABS light. So, is there any problem related to the EBD insted of ABS ?
I checked my car's braking fluid and noticed that the fluid level is in the max line.
Based on what I just wrote, does anyone know what might be the issue? Could it be the ABS Module? What do you think?
  • 0
20 hours ago, João 02 said:
Can you send me some photos of this part of the ebd. Excuse my ignorance but I didn't find anything about this in the manual on this site
Follow this two flowcharts. First check if you have any DTC store for the ABS. If the ABS light doesn't start blinking after one blink, you don't have any error stored. If you have an error, check that first. If the light is constantly on and doesn't enter in the DTC mode, you have a faulty ABS Module. If you don't know how to read ABS faults, just check the manual in the ABS section.
If you need more help just PM me and i will help you in Portuguese.
Answer this question...
