Headlight Washers
IceMan
The headlight washer jets have a seperate pump, its probably knackered, i know mine is!! When I got mine, i hit the button and nothing happened. I checked the fuse, and found it blown, so I replaced it. Now when I press the button I can hear the relay click, but they still dont work, is that what you are experiencing?
best way of testing that is remove the front bumper so you can get at the pump . pull off the electrical connector to the pump get some one to press the botton if you have a feed its the pump, if there is no feed work your way back fuses, relays, switchs, wiring. Rich.
