ecu immobiliser
jocky2k
Just a quick question. I have a vtec ecu for my conversion but it has part of the immobiliser in it (as far as I'm aware anyway!) And I was wondering if there was a way around it as I don't have the other half of the immobiliser.
The ecu is out of the 1.6 Sr and I no that the one out of 1.6 esi the p28 plugs straight in and works. So the only thing that I can think of is immobiliser!!
Any help would be greatly received!!
Oh and my car is an mb3.
It reads the code from the key with its in the ignition and turns the immobiliser off . you will need the one off the car you got the ecu from and the key to go with it and then it will start , the box is under the steering coluum . Rich.
We have a bloke in a van that comes to my work to put out all the airbag lights a stuff for us , he is loads cheaper than the main dealers , he charges £50 to put a light out im sure he would be able to help with your problem have a look in your local area and see if there is some doing the same and give them a call . Rich.
