bigbear Posted September 15, 2010 Share Posted September 15, 2010 Not sure if this is in the right section but when changing the brake fluid, which way round to bleed first? Is it rear passenger, then rear driver, front passenger then last right drivers side? Link to comment Share on other sites More sharing options...
bigbear Posted September 15, 2010 Author Share Posted September 15, 2010 Not sure if this is in the right section but when changing the brake fluid, which way round to bleed first? Is it rear passenger, then rear driver, front passenger then last right drivers side? Link to comment Share on other sites More sharing options...
johngreen537 Posted September 15, 2010 Share Posted September 15, 2010 Longest brake line to shortest brake line usually...So, I think you're about right! Link to comment Share on other sites More sharing options...
jalesi2001 Posted September 17, 2010 Share Posted September 17, 2010 Yep, start on the wheel thats furthest away from the master cylinder.So, N/S/R, O/S/R, N/S/F then O/S/F. Link to comment Share on other sites More sharing options...
