syder Posted November 5, 2010 Share Posted November 5, 2010 I have taking the engine out of my MC2 to be repaired as the beast was burning oil alot , has done 224900 ml , the engine has been taking apart and they found out that the bores are burd and need re boring , No 4 cylinder was the worst and they said that the thing was ready to go bang on me , No 3 was badly carbon ed , No 2/1 were slightly bured .They need to be over-bored to point 5 , they are unsure as to whether or not it safe to do this with the metal on the engine and uprate the pistons , they asked me if i knew but no i don't , so i ask you good people of civic5 to help me please .Is this going to last long if over-bored to this size with the new size pistons in ? Link to comment Share on other sites More sharing options...
bepilot Posted November 5, 2010 Share Posted November 5, 2010 is this miles?aren't you better off to find another block in the breakers than rebuilding this mileaged one?... Link to comment Share on other sites More sharing options...
syder Posted November 5, 2010 Author Share Posted November 5, 2010 The rest of the engine is spot on its had a total strip down , then if the bores can be uprated then the rest will be done as well uprated cams/valves/full polish the lot , so why buy another engine for when this one can be better. Link to comment Share on other sites More sharing options...
cal Posted November 5, 2010 Share Posted November 5, 2010 yes .5 over bore is fine.the engine will last long as its been put together correctly to honda specs Link to comment Share on other sites More sharing options...
syder Posted November 5, 2010 Author Share Posted November 5, 2010 Ok cheers, now where do i buy pistons oversized to .5 . . .. loads of discussions online but no link as to where to buy them from. Any clues? Link to comment Share on other sites More sharing options...
cal Posted November 5, 2010 Share Posted November 5, 2010 are you going higher comp or do you want stock compression.U.S ebay have some good deals on itr, ctr, sir pistons Link to comment Share on other sites More sharing options...
syder Posted November 5, 2010 Author Share Posted November 5, 2010 i'd like a higher compression really, ill have a look on the usa ebay... cheers Link to comment Share on other sites More sharing options...
civicturbo79 Posted November 5, 2010 Share Posted November 5, 2010 Us ebay is the place to look mate , if you are going 0.5 mm over size that will be fine , you will need 81.5 mm pistons . If you raise the compression you are going to need the car mapping once you are done with the engine build or it will not last 5 mins . I use cp pistons . Here is a link for you . http://cgi.ebay.com/ebaymotors/CP-Pisto ... ccessoriesThis bloke is selling cp pistons and if you look down the listing there are all the part numbers for all the pistons you need :SC7011 81.50mm (+.020" Overbore) 9.0:1 (STANDARD REPLACEMENT)SC7111 81.50mm (+.020" Overbore) 11.0:1 ( HIGHER COMP)SC7116 81.50mm (+.020" Overbore) 12.5:1 (EVEN HIGHER COMP)Rich Link to comment Share on other sites More sharing options...
syder Posted November 5, 2010 Author Share Posted November 5, 2010 Nice one thanks for all your help Will now be departing with loads of money 5k on the engine maybe then a new respray Will be showing some pics soon Ha the bloke diong my engine is so impressed with it he is thinking of buying one him self Link to comment Share on other sites More sharing options...
