Dam abs problems
the mad kiwi
the light has been since i realised the last owner had unpluged the light banghead.gif1
a while ago i pulled the codes RHR sensor so no biggie ,i replace it a few weeks back and still the light was still on
after a bit of crash.gif1 it looked like the pump/ecu so i found one of them and after a lot of complain.gif1 its been replaced as well
now things have changed b4 the light was on as soon as you turned the key now it thinks b4 it comes on but then doesnt turn off and now it wont give me any fault codes notworking.gif1
any ideas? idea.gif1 or shal i just eekout.gif1
im sure theres a sequence to clear the abs codes by pressing the brake pedal whilst bridging the contacts to get the codes if i come accross it again ill post a link for you mate.
here we go taken from ek9 forum
If you need to reset the abs light, try this:
If your ABS light is on and you need to clear wheel sensor codes, follow these steps:
1. Put a paperclip in the SCS connector (like you do to read the code)
2. Hold brake pedal
3. Turn key to position II
4. When ABS light goes out, release pedal
5. When ABS light comes back on press brake pedal again
6. When ABS light goes out, release pedal once more
After a couple of seconds the light should blink twice, at that point turn key OFF and wait 10 seconds. Your codes are reset.
  • 3 weeks later...
2. Hold brake pedal
hi all
my abs light has been on a while now .
iv tried to reset the faults by following the above but doesnt seem to work for me .
is there owt else i can try . thanks !!
nealy forgot its a 1999 1.8 vti mc2 aerodeck .
