lowering, which way to go,
philgor
hi, i'm looking at lowering my mb1 1.6ls automatic, i don't want to go stupidly low, i only want a small drop, i'm looking at zs 120/180 setup, as i could get the whole lot brand new for about £100/150. should i consider anything else before i go ahead with the zs set up?
also which set up should i use if i do use the zs set up, 120 or 180, the car is a mb1 with a d16 engine with an auto box
Standard mg zs 180 will sit to high at the front cos diff engine weight
Best to mg zs shocks and then lowering springs
Im a bit confused...but wouldnt that mean the mg zs shock absorbers would still be too long for lowered springs?
I read somewhere the shocks have to be right size to the lowered springs. Can someone clarify?
