Shaddow Posted February 9, 2011 Share Posted February 9, 2011 Hi.I tried to replace the bulbs behind my heater switches on wkend, but could not quite get to them, as I discovered I also have to disconnect all the mechanical parts between the switches and the air ducting of the car.I put everything back together but since then my clock in the centre does not light up any more when I switch my light on. Is this just a fuse or is there also an actual bulb behind the clock display to illuminate the display? Can this be changed fairly easily if needed?Thanks Link to comment Share on other sites More sharing options...
johngreen537 Posted February 9, 2011 Share Posted February 9, 2011 Yes mate, on both counts!Have a look see in the how to section,I'm sure theres one specifically for changing the clock light! Link to comment Share on other sites More sharing options...
