sblaber Posted May 5, 2011 Share Posted May 5, 2011 I am looking to fit an aftermarket alarm to my MB6 this weekend as it currently only has the standard manufacturer immobiliser. I was wondering if anyone knows what colour the lock/unlock wires are and where the central locking module is located.I'm pretty sure Civic's use a negative pulse activation, just need to fint the relevant wires. Link to comment Share on other sites More sharing options...
johngreen537 Posted May 6, 2011 Share Posted May 6, 2011 Download the workshop manual mate. Definate answer in there Link to comment Share on other sites More sharing options...
Silverdeck Posted June 5, 2011 Share Posted June 5, 2011 I have tried to download the manual but it never worked, so I tested the wires on the drivers door central locking plug with a multimeter, I think the red/blue wire and the red white wire control the solenoid switch (lock /unlock)the thicker red/yellow and red white actually fire the solenoid (up/down)I still havent figured out quite which wires to splice into Pic of the wiring diagram for the central locking unit Link to comment Share on other sites More sharing options...
mattmb2 Posted June 25, 2011 Share Posted June 25, 2011 This is the cheat sheet that should help you out if not already sorted, although your alarm doesn't list the correct configuration on your photo but this can be over come with 2 12v changeover relays. I've attached the laserline diagram, the top one diagram 'E'. you need to cut the white/red and yellow/red you've already found.http://i222.photobucket.com/albums/dd75 ... ic1996.jpghttp://i222.photobucket.com/albums/dd75 ... iagram.jpg Link to comment Share on other sites More sharing options...
Silverdeck Posted July 25, 2011 Share Posted July 25, 2011 ^ Many thanks for that, could you show an ebay link to 12v changeover relay i typed it in but not really sure what I'm looking at Link to comment Share on other sites More sharing options...
