bs_vti-s Posted June 16, 2011 Share Posted June 16, 2011 had a bit of a stupid accident and now need 2 new doors. i have rcl so im not sure how smooth the switch will go. will the new doors work with the rcl or will i need to try and locate the wiring in my current doors to make the new 1s work. Link to comment Share on other sites More sharing options...
bepilot Posted June 19, 2011 Share Posted June 19, 2011 first try to swap the doors as is (with removing the interior trim of them) and connect them up to see what it gives, I've scanned the location of the connectors from the workshop manual, on the rear doors from memory remove the plastic rubber crimp (the one that connects the harness to the door-chassis) and you should find the find the connector side. Sorry for my english, the pics says it all - on the front door, the connector appears to stick out. Link to comment Share on other sites More sharing options...
