ritchiegray1983 Posted July 2, 2011 Share Posted July 2, 2011 I've done a diagnostic check with a paperclip and 2 codes have showed up. 72 - Random Misfire on cylinder2 and 92 - Evaporative Emissions Control system - Insufficient purge flow.Not sure what to do from here so any advice would be great.Cheers Link to comment Share on other sites More sharing options...
noodels Posted July 2, 2011 Share Posted July 2, 2011 92 google it! says replase fuel cap ect /evap canister/vac lines blockage, canister under battery ?cap first it recomends!! Link to comment Share on other sites More sharing options...
ritchiegray1983 Posted July 3, 2011 Author Share Posted July 3, 2011 I've googled it and asked a few mates and there is a wide area to cover lol. check for corrosion on the dissy conections, new spark plugs reset ecu, clean and check fuel cap/evac canister and lines lol gonna be busy for the next few days at least. where is best to buy replacement bits as i'm not loaded enough to order new from honda, well i'll find out later if i'm loaded enough by checking out the prices. still expection OEM to be OTT. Link to comment Share on other sites More sharing options...
ritchiegray1983 Posted July 7, 2011 Author Share Posted July 7, 2011 turns out i was watching the SRS indicator flash code 72 and 92... just needed to reset the SRS other than that the car does seem sluggish and kinda wobbly. think i just need to run it on the dyno and see what's up with it. Link to comment Share on other sites More sharing options...
