Nav Posted July 25, 2011 Share Posted July 25, 2011 I recently installed Energy Suspension Torque mount inserts, and I can really recommend them!A cheap mod, with direct result!Also have shifter bushings from Energy Suspension, an my gear lever now sits still.. before it was very wobbly..Just out of cruriosity, how dose changing torque mounts inserts help with the wobbly gear lever...Mine is very very wobbly even when in gear( its quite bad)....i tot is was somthing to do with the gear linkage bushes...sorry if i sound a bit daft... Link to comment Share on other sites More sharing options...
Errordeck Posted July 25, 2011 Share Posted July 25, 2011 well with loose mount the engine moves around a lot. New mounts block it's movement, therefore gear lever sits more still. Of course shift linkage bushings should be OK as well.. Link to comment Share on other sites More sharing options...
Nav Posted July 25, 2011 Share Posted July 25, 2011 OK ordered some Energy Suspension Shifter Linkage Bushing... lets see how this will affect the wobbliiness...if that dosent help then Energy Suspension Torque Mount Inserts.... i hope this fixes it and it will be easy to change...fingers cross... Link to comment Share on other sites More sharing options...
Nav Posted July 25, 2011 Share Posted July 25, 2011 I recently installed Energy Suspension Torque mount inserts, and I can really recommend them!A cheap mod, with direct result!Also have shifter bushings from Energy Suspension, an my gear lever now sits still.. before it was very wobbly..Did u change the Shifter Bushings urself..?? could you explain how u manged to get the old bush out and the new one in... Link to comment Share on other sites More sharing options...
Errordeck Posted July 25, 2011 Share Posted July 25, 2011 yes I did it myself.Not much to it. Unscrew the bolt by the block, save the inner metal bushing and put in in the Energy Suspension bushing, tap it into place and bolt it back together again. Then make your way to the lever, unschrew 2bolts, slide the rubber of and the Energy Suspension on, and bolt it al back together. That's all..edit: i could take out the old rubber with bare hands. Putting it together required some ticking with tools, but really nothing hard. Link to comment Share on other sites More sharing options...
Nav Posted July 25, 2011 Share Posted July 25, 2011 yes I did it myself.Not much to it. Unscrew the bolt by the block, save the inner metal bushing and put in in the Energy Suspension bushing, tap it into place and bolt it back together again. Then make your way to the lever, unschrew 2bolts, slide the rubber of and the Energy Suspension on, and bolt it al back together. That's all..edit: i could take out the old rubber with bare hands. Putting it together required some ticking with tools, but really nothing hard.Ohh boll**ks.. i just bought a set and i just remembered i only replaced the bushing by the block a month ago with OEM ones...looks like i will be selling mine off...damn it.. too eager to buy... Link to comment Share on other sites More sharing options...
