Shaddow Posted September 5, 2011 Author Share Posted September 5, 2011 Hi Rich, just re-wired, and Yay! the oil temp gauge now works, but oil pressure is still giving no reading and light flashing. Before I go and open up every terminal connection I made, could you suggest which is the most likely to cause the problem.Thanks Link to comment Share on other sites More sharing options...
civicturbo79 Posted September 5, 2011 Share Posted September 5, 2011 I would start by checking the earth to the sender unit and the sensor really need a good earth, put the earth to the body rather than the battery . After that i would go for the green wire from sender to gauge , after that i would say you could have a faulty sender unit . Rich. Link to comment Share on other sites More sharing options...
